bt sport
  • jimbojimjay
    • Oct 2008
    • 149
    bt sport
    cant pick up bt sport when doing a scan any ideas thanks
  • ramalhosatelite
    • Oct 2013
    do a satellite scan after unplug the box and plug it back and you will found a few bt sports one of them will work
    • ramjet
      • 2995
      and your equipment and image or patch is ????????????????????????????????????
      • jimbojimjay
        • Oct 2008
        • 149
        sorry about that ,its old eagle 1000 with the commando image on,had bt sport 1 and 2 but just went of list and tried loads of scans just not picking it up thanks for any help
        • mickm1
          • Feb 2011
          • 46
          I did this for E1 box, you will know how to manual scan a transponder im sure but the freqs etc are samepress menu
          setup
          service searching
          manual transponder scan
          fill in boxes as below
          Frequency 10978
          polarity vertical
          FEC 5/6
          symbol rate 22000
          then press green ok to search. once complete to access new channels exit when done and BT sports should now work
          • jimbojimjay
            • Oct 2008
            • 149
            setup
            service searching
            Frequency 10978
            polarity vertical
            FEC 5/6
            symbol rate 22000
            tried that mate keep getting transponder fail after a few seconds thanks again for your help
            • ASEK
              • Feb 2010
              • 1686
              try 10979 freq symb 22000
              • ramjet
                • 2995
                its actually on 12515 H 22000 , check king of sat for details
                • ASEK
                  • Feb 2010
                  • 1686
                  Well it's on 11156 /23000 or 10979/22000
                  • ramjet
                    • 2995
                    and if the court rules against one of the 2 parties it could well disappear by the 10th october , as at the moment its being dual fed pending a court decision
                    its also not just bt sports as dozens of channels are affected
                    • benny/9
                      • 1964
                      i have the channels open on a vu solo2
                      11156-v-23000 for the HD chns
                      10979-v-22000 for the SD chns
                      Please Read Carefully!
                      • mickthefish
                        • 30
                        I had this problem with several E1 box's this week DM500s. The box's did not find any of the moved channels when scanned. The answer was to go into openpli website and download the new DM500 firmware they have just put there to solve this E1 problem. Flash the box with this firmware, do a automatic scan 28.2 then happy days. When commando update their firmware go back to your image of choice. There are plenty of E1 sky bouquets lists with the bt channels and updates on them knocking about.
                        • jimbojimjay
                          • Oct 2008
                          • 149
                          thanks for that just updated commando then did rescan still no bt sport any idea's thanks again
                          • Nutsandbolts
                            • Oct 2011
                            • 1168
                            Hi. Is your dish aligned correctly to pick up the new frequencies??? If possible try a second receiver and see what happens. Also is it one of those old type receivers where you have to delete the old channels before it scans the new ones in??.
                            Regards.
                            • ALAN 1
                              • 60
                              Final freq for BT 1/2 12574H, sym 23000. They will be more freqs changes in 4 to 6 weeks when Astra2E will replace Astra 1N when Astra 1N moves to 19 east.
