Hello and thanks for the welcome. First question. I have a Spiderbox HD9000 tuned into Astra 2a/d at 28.2e degrees. frequency 10714H 22000. Newcamd. I lost BT sport last week and have struggled to re-tune since. I understand that the frequency has changed. Can anyone help with the procedure for a manual scan with the spiderbox? Please be patient I am a beginner.
Spiderbox HD9000 TP settings
loads of channels moved and in moving process,maybe a new scan is needed to pick up new frequencies,unless you have upto date bouquet
manual scan only does 1 tp
automatic scan does whole sat
best to do with so many moved is automatic scan as it overwrites old list to a newer list.Last edited by cactikid; 6 October, 2013, 14:28. -
unfortunatekly you havent mentioned if you mean the HD or the SD channels , or both
anyway, the first thing to do is visit king of sat or lyng sat and get the latest transponder details
then press menu - manual scan - tp add (press green) and put in the first transponder and hit start search at the bottom, saying yes to save first
after its scanned in say yes to save the channels and transponder
repeat for the next ones until all are in the channel list for 28eComment
