Vivabox 7000 hd channel list
  • hodgey99
    • 9
    hi can anyone help me getting a channel list for the vivabox looked everywhere but cant seem to find one anywhere thanx
  • ramjet
    • 2995
    been in this game over 15 years and never, never heard of it and never seen it on any sat forum either
    so I doubt you will get any info on it
      I could only find information from here:
      To source a channel list or even the format it is in we would need to know what original box this is as in Cloned or a re-badged version
      • hazletree
        • Feb 2012
        I have the files but not sure how to post them up on here????
          Turn it in to zip file and post it as attachment easy.
          • hazletree
            • Feb 2012
            Viva box files
            Here you go this is the firmware and the channel list hope it helps
            • faizyan6000
              • Feb 2011
              • 37
              Any body having problems with signal quality on this box
                Asking a bit to much for a 30 quid box!!!
                  How to install channel list I tried with USB stick it did not work, any idea?
                    channel list you all been waiting for.
                    • vivabox
                      • Jun 2014
                      Hello, I already installed it. It is old one.
                      I need some channel list for 28.2E astra 2E.
                      My satellite antenna already aligned some frequence of 28.2E.
                      But I can't see BBC channel. Could you give me your advice?
                      I'm in south France. the antenna for satellite is 110cm. and Viva HD7000.
                      I can't see any UK channel.
                      Best Regards
                        How we suppose to know you are bassed in France, other day a person needed help in Africa, at list tell us your locasion if you all need help!!!!
                        • vivabox
                          • Jun 2014
                          Sorry, I assume you are the specialist. I just ask your advice about the reason why i did not get the channel even if i aligned the Astra 2E (28.2e) and got the signal of the BBC frequency and respond.
                          • thebrief
                            • Aug 2014
                            Vivabox setup
                            Quite by coincidence, I am trying to set up a Vivabox 7000HD in France as well. I got a pretty good channel list for Astra 2E, including BBC and the box worked well before the 2E signal went bad on me due to poor weather (I need a bigger dish!).
                            There are a few teething problems though. Its all very well having firmware upgrades via a PC or USB, but that's not much good if you can't find a supprt website. The box and instructions don't mention any manufacturer. Any ideas?
                            More importantly, I specifically bought this on ebay UK as the cheapest satellite FTA freeview box I could find with built in wi-fi. That's what every ebay and retailed webiste says is a key feature. Now that the Astra 2E satellite signal has gone down, I tried to set up wifi. However, the setup routine says there is no wi-fi device detected. Have I missed something?
                            Basically, any info at all about this box would be helpful - thanks.
                            • Mrdium
                              • Oct 2014
                              • 4
                              I am having a big problem, I just bought a new one, and the install Antenna option is disabled.
                              How can I start searching for FTA channels?
                              Will this Firmware upgrade solve the issue? Is it the latest one?
                              Any help please?
                              Thank you...
