does anybody have a channel editor soft wear for spiderbox 9900?
spiderbox channel editor
Tags: None
attached 2 below
also added latest softcam tooCode:Spiderbox MacSatellite Manager r12 *Changed the way error logging is done, txt files do not get created anymore. *Changed the default open/save favourite prompts to the application start up directory. *Improved Favourite Import, PREVIOUS FAVOURITE.XML FILES WILL NOT WORK WITH THIS VERSION. *Removed Create Ethernet Favourites, its no longer required. *Added ability to Save/Import BISS Keys for the Spiderbox. This is recommended for new releases. *Added ability to Save/Import DVB-T Freqs for the Spiderbox. This is recommended for new releases *Added ability to sort channels by default in Edit > Settings, channels are saved and sorted by the various options available. *Added DVB-T Frequencies to the Spiderbox Tab (Freqs only, NO Channels as the UK is mainly region specific). *Changed the Spiderbox UDB code to minimise errors/failures from *********. *Changed 2.9E to 3E, 2.9E does not exist on the ********* website. *Fixed issue with an error appearing when deleting favourites. *Added Slight delay when re-arranging favourite channels to fix the scroll bars moving too fast. *Added Delete Key action that will delete channels as an alternate to Right Click > Delete Channels. *Added Description column to BISS Keys table to help keep track of what key opens what package/channel. PREVIOUS DATABASE FILES WILL NOT WORK WITH THIS VERSION Version 12 - 31/10/2012Comment
