CT4100 fw on DR HD D15 OK!
  • satman2
    • Aug 2009
    • 36
    I have loaded this but the Men? nackground is not same with ct4100.whats wrong??
  • benny/9
    • 1964
    i'm always dubious about using software for other models
    as i have seen loads of posts about bricking boxes etc:
    so if things dont look right,have you tried loading the correct
    DR patch and checking that it loads and the box is still ok
    Please Read Carefully!
    • satman2
      • Aug 2009
      • 36
      both boxes are almost identical! 99%! and it is not a foreign model!
      and I've never shot up one of my boxes. software loaded on it a hundred times, a hundred times aborted software .. I know what I'm doing and the software runs very well on hd dr.
      CT 5000 HD Combo Plus F16 >> DR works.
      dr hd, CT, blade media, Strong Japan/australia all come from the same factory!
      • mdt
        • 3034
        why do you want to put other software on your D15 anyway?,regards mdt
        • satman2
          • Aug 2009
          • 36
          just like that because that has a different menu and the sat scan structure is different and simpler than in D15! and the CT has some more functions ..
          D15 sat scan is more complex!
