Still Struggling with 42east
  • telveskid
    • 115
    Can Anyone Advise Me
    Got a 1 Metre Dish @42east getting 82 % signal on most channels but when i try for Rustavi2 & 1tv Georgia it drops to 65% picture Pixalates badly
    Ive even fine tweeked the Motor East n West but no avail
    And the LNB Skew is set to Zero
    Any help Aprreciated
    What receiver are you using and on a Fixed dish pointing to 42? east the LNB skew should not be on zero, Those 2 channels are on 3A west so should easily be receivable with that size of dish. Try altering the skew while tuned to one of those channels
    • telveskid
      • 115
      Hi ,
      Am Using a Old TM-1500 on a motorised 1 Metre Dish
      Any ideas
      Kindest Regards
      • jimleeds
        • Jul 2012
        • 25
        id make sure the skew is set at 0 when your aligned to 0.8w and it should be about right when you move to 42e i fitted a fixed 80cm dish last week to turksat and you wouldn't believe the difference an adjustment on the lnb make to signal quality when at 0 it was reading around 20-25% adjust the skew and it went upto around 95-97%
        technomate tm-2t oe attached to a tm2600 with a 1m dish
        • Nutsandbolts
          • Oct 2011
          • 1168
          Hi. If you have moved the dish slightly left/right and still no signal then it could also be your dish is a fraction too high. Try and toggle the dish with your hands up and down and see if it gives you the signal. Also double check you have correct frequency otherwise you will never find it unless you do a blind scan.
          Regards
            Rustavi2 on 11881 V 27500 & 1TV Georgia coming in at 95% currently raining here on my 1.2m dish with Black Ultra Twin with Skew set to '0' on Motorised system
            Regards
            • ramjet
              • 2995
              also, as mentioned in your previous thread (why 2 threads on the one topic I dont know!) they are both loud and clear on the same transponder on my spiderbox on 42e from my dish here in the n/w so any problems are down to dish alignment or skew, or both, so as said previously have the skew on zero at 0.8w and let the motor do the work
              • telveskid
                • 115
                Thkanks Everyone For your Input Really Appreciate it.
                Am going to send Dish back to 1 West check LNB Skew is Bang on Zero (BBC WORLD NEWS) and take it from there
                Regards
