Skybox f5 or dream box bm7000s???
  • Badger008
    • Oct 2013
    Hi
    im fairly new to this. I know people with skybox f5 but I want to be able to record more than 1 channel at once, and I've been told the series link can be a little funny on the f5.
    any advice will be very much appreciated
  • ramjet
    • 2995
    bm7000s is not a dreambox, not linux either, and only has one tuner
    good box but wont do what you want due to one tuner only
    the F5 is a cheap single tuner box so again no good for what you want
    have a read through this, picking out twin tuner boxes like the duo 2 or solo 2 or tm twin
    • Badger008
      • Oct 2013
      Thanks I will have a read and yes I ment blade bm7000, I read somewhere you could record more than 1 channel with it!!
      Obviously false info!!
      • rigsby71
        • Mar 2009
        • 676
        Yes, you probably can on the blade providing the channels in question are on the same transponder.
        • ramjet
          • 2995
          as above, I just didnt want to confuse you with the gory details, clearly you were already confused by them
          so yes if the channels are on the same transponder, but usually people want to record one channel and record any other channel that they wish to, not constrained by the single transponder caveat
          its rare that the 2 channels you want to record (or watch and record) will actually be on the same transponder, so I gave you the simple answer based on experience instead of the limited theories
