Don't know why motorised dish to buy?
  • brookey12
    • Sep 2011
    • 20
    Hey guys
    I need some help.
    Im looking to buy a motorised sat dish but having difficulty on which one to buy, im in the UK if that helps,
    What channels can i get when comparing a normal sly dish to a motorised dish? can i get aljazeera sports with a motorised dish? What other channels can i get? i have about ?150 to spend in my paypal account so would prefer to buy off ebay so i can use the money in my paypal account, been looking at this page motorised satellite dish | eBay
    but there all different prices which i dont get why?
    Thanks in advance
  • ramjet
    • 2995
    I would assume you are asking about the al jaz channels on 26e or 7w and you wont get them without a massive dish here in the uk, so you will need to forget about those
    the triax td110 dish or a gilbertini or andrews or something similar is good for most stuff here in the uk bearing in mind the maximum size allowed is 1 metre without planning permission, subject to local bylaws
    you can check what sats and channels you will get using dishpointer and king of sat or lyng sat for broadcaster info
    also have a look at this thread here http://www.digital-kaos.co.uk/forums...-setup-301108/ for various info
      you would be better with separate's so you can get a half decent system instead of buying an all in one package that may have 1 or 2 good items
      Dish: Orbital Steel 1m 100cm Satellite Dish Brand New with Lifetime Warranty | eBay
      Motor: Superior Dark Motor All Metal DiSEqC USALS | eBay
      LNB: INVERTO BLACK ULTRA HIGH GAIN SINGLE LNB 0.2DB BUYME | eBay
      Total : ?112 or there abouts
      Also factor in the cost for a wall mount or if your going to get someone in to fit it you may be better letting them get the Mount for you.
      Regards
      • brookey12
        • Sep 2011
        • 20
        Regards
        Thanks for the reply guys, so if i buy what u suggested above then all ill need is a wall mount is that correct? also does it have to be really high up (the dish) or can i put it above my living room window etc? Also what about this 80cm MOTORISED SATELLITE DISH DiSEqC 1.2 MOTOR + 02 LNB | eBay does this have everything i need etc?
        • brookey12
          • Sep 2011
          • 20
          Also regarding channels would i get USA Channels like USA Network, CW, Stuff like that??
          • ramjet
            • 2995
            usa channels are aimed at the usa so you wont get much here in the uk
            there are a few usa channels on 15w that we can pick up here in the uk
            • brookey12
              • Sep 2011
              • 20
              Such as? What about things like Sky germany or things like that?
              • ramjet
                • 2995
                already given you 2 sites that you can check broadcaster details from your location, and dishpointer will let you check what can be received for your postcode by hanging a dish on your property and checking line of sight from each satellite (this forum has no way of knowing what obstructions are in the way for you)
                also you need to not be talking about sly - please read the rules here
                • brookey12
                  • Sep 2011
                  • 20
                  My apologies
                    Most of that is cheap tat dont get me wrong if your on a budget and want to be thrifty with the wallet then go ahead but personally would not touch that with a barge pole
                    An 80cm the system you quoted will get you a lot of satellites but do not expect miracles thats all i am saying
                    • brookey12
                      • Sep 2011
                      • 20
                      On my details on dishpointer heres what it says:
                      Address: My address
                      Latitude: my latitude
                      Longitude: my longitude?
                      Satellite: 82W, 91W, 110W, 119W
                      Elevation: -12.8?
                      Azimuth (true): 95.5?
                      Azimuth (magn.): 98.1?
                      Where it says satellite does that mean what sats i can receive?
                      sorry for all the questions bit of a newbie with installations but fast learner once i get going
                      • brookey12
                        • Sep 2011
                        • 20
                        Yeah thats fine mate id rather take advice from you thats for sure so ill get what you said but just to confirm that the stuff you listed that you recommend i get then all i need is a wall bracket as well is that correct? any one in particular you recommend? with the dish you recommended that one will get me more channels than what i will get with the one i said about??
                        what about leads etc cause in the one i suggested it shows that it comes with leads so would i need to buy leads as well etc?
                        • ramjet
                          • 2995
                          on dishpointer you can select each satellite in turn , or you can set the range of satellites that you may be able to receive , so say from 42e to 45w for instance
                          ideally use T-K brackets and scaffold pole for mounting, and yes you need sat grade coaxial cable to connect to the motor and lnb
                          you can have the dish on the ground if you so wish, height is not an issue unless you have obstructions like trees and walls and buildings
                          • brookey12
                            • Sep 2011
                            • 20
                            Just so i got this right?
                            On dishpointer you got
                            Your location: here i enter my postcode
                            Then under that:
                            Most Popular Satellites in country flag
                            1. 28.2E ASTRA 1N | ASTRA 2A | ASTRA 2D | ASTRA 2F
                            2. 13E EUTELSAT 3C | EUTELSAT HOT BIRD 13B | EUTELSAT HOT BIRD 13C
                            3. 19.2E ASTRA 1KR | ASTRA 1L | ASTRA 1M | ASTRA 2C
                            4. 16E EUTELSAT 16A
                            5. 26E ARABSAT 5B (BADR 5) | BADR-4 (ARABSAT-4B) | BADR-6
                            Then under that theres this
                            All Satellites | Motorized Systems | Multi-LNB Setups:
                            then under that its a drop down menu,
                            If i click on motorized systems the drop down menu changes, when it changes and i open the drop down menu is that all the satellites i can receive??
                            • brookey12
                              • Sep 2011
                              • 20
                              also i typed in TK Brackets and theres a few there : T K Bracket: Sound & Vision | eBay any in particular you recommend with the items im gonna buy that digicon recommended? also how long of a coxal cable should i buy? roughly?
