Getting Better Signal level & Better Signal Quality
  • telveskid
    • 115
    hi Guys Can you help ?
    Am using a motorised 1metre Dish & TM 1500 CI but am having problems
    For Example on
    39east am getting Signal Level 93%
    Signal Qual 72%
    Picture is breakin up because i think these levels should be higher all round.
    Also 10% lower on each again on 15 WEST.
    Any ideas ????
  • ramjet
    • 2995
    seem ok to me given that you are in the uk and those channels are not broadcast at us here in the uk, so you are never going to receive them as well as 13e or 19e or 28e
    • Benzade
      • Nov 2011
      • 95
      Those signal levels are about correct for 39e Telveskid I live in the North West of England and the most I've ever had out of 39e is 80% Signal Quality on a clear day in the Summertime. I don't suffer picture break up though even with the levels you've quoted unless It's really bad weather.
      You could try tweaking with your motor but it's hardly worth it for what % more you may squeeze out of your Signal Quality on 39e at this time of year.
      Regarding 15w you should be getting better strengths on that as I have no problem pulling that satellite in using similar equipment to yourself and it may be worth tweaking your motor in setup on that satellite to see what gain you can get from it.
