TvZimbo is on the Africa beam and not possible to pick up in the UK if your inputting 11676 H 11170 7/8 on 10e and if you're using the details 10758 V 02480 7/8 then you're trying to input a feed transponder which probably won't become live until just before the time of broadcast.
Depending on your dish size getting TvZimbo on 7e is probably your best bet on 21605 H 02480 7/8. At least if you can't get it on that transponder on 7e which should broadcast TvZimbo all the time then you'll know not to bother and to try ESPN on 15w instead.
I've found "African" channels to be very hit and miss regards FTA EPL Telveskid. Best to stick to what you can rely on especially when you can have English commentary. A good tip is to check the ESPN Caribbean website as LJs Live doesn't always list them as showing EPL games when they actually are.
