two satellites?
  • jacquesy90
    • Dec 2013
    • 92
    two satellites?
    I live in an apartment buliding and behind my tv ther is 2 sat inputs, sat 1 and 2.
    im connected to sat 1 and everythings fine. just curious as to what the 2nd sat input is for as im sure there is only one sat on the building?
  • Hadron
    • 2102
    Have you tried connecting your box to the 2nd socket to see if it works?
    You might have 2 feeds to the LNB for Sky+ recording.
    • M T Glass
      • Jul 2013
      • 733
      Or, maybe you could run a sat cable from the second connection to have another box running in another room.
      Official Meat-Head Fan Club Member (member number 14300)
      • jacquesy90
        • Dec 2013
        • 92
        No i havent tried it, is that what the loop input on my skybox f5s is for?? if i run a cable from loop to sat 2 will i be able to pause and rewind etc??
        • Hadron
          • 2102
          You can already do basic pause, rewind etc. if you plug in an external hard drive or memory stick into the USB port on the F5s.
          If you have a box fitted with 2 tuners, like the official Sky+ box, then you need 2 feeds to the box to be able to watch 1 channel while recording another.
          The loop is an output, not an input. It simply loops the LNB input, back out to the loop connector.
