The Right Receiver and help please
  • 0nl1n3
    • Jan 2014
    • 5
    Hi everyone
    I would like some advises,
    1. I want a buy a receiver that can have optical, HDMI, Ethernet, If possible wifi or to be able to add a wifi stick, cam slots,card reader, usb for disks,record movies on disk, unlimmited channels, flexi software and easy to use .
    2. I want to be able to stream my videos on the internet and be able to watch them online .Any guide will be very helpfull
    Thanks a lot
  • ramjet
    • 2995
    the main choice for the above requirements is the vu duo 2 (as long as your BB upload speed is good for the streaming)
    cheaper but not as good alternatives are the vu solo 2 , possibly a few others but they will be linux based and so be a challenge compared to bespoke boxes
    option 2 is what will limit your choices severely, hence my reply, but the duo 2 should be ideal
    • 0nl1n3
      • Jan 2014
      • 5
      Thanks for your Reply , do we have any good tutorials on how to setup my receiver and stream my videos,thanks
      • ramjet
        • 2995
        check the VU forums here on DK for advice on setting them up etc
        • happy_highlander
          • 3535
          To stream from linux box to internet you have two options. First option rely's heavily on your bb upload speed as mentioned by ramjet and of course the box. Set up box with dns address and forward ports on router as necessary, this will allow access to content stored on hdd via ftp allowing you to use xmbc or the likes on a pc to view the recorded content, dns address will also allow connection to webif for streaming channels direct from box using vlc to view the m3u file the sent by the box for the stream. The other option will only allow you to stream channels but will require someone to be in the same place as the box to start the stream. This is done on pc via veetle and doesn't use as much bandwidth as the stream quality can be reduced to give best possible picture available over your bb connection in much the same way as you would watch a footie stream. The choice is yours but none of the options are very novice friendly and require a bit of networking knowledge as well as a bit of linux knowledge a yet again a good bb upload speed.
          • blueflash234
            • Mar 2009
            • 904
            don't know if its released yet but the new xtrend 10000 would fit your requirements and looks as if its going to be the box to beat all others
