TSpanel
  • jacquesy90
    • Dec 2013
    • 92
    TSpanel
    Hello folks, can someone point me in the direction of a tspanel file that actually works in vix, im running the latest image
    I Think if you do a search on the forum you will find its not compatible with the Vix image or i should say if you do get it running on Vix you may find its very temperamental
    • jacquesy90
      • Dec 2013
      • 92
      i know ive read some things, and ive had bad experiences with a build myself. but ive also been told that builds 3.2-7.3 willl work on vix.
      with it being my first vu+ box i really want to try this plugin to get the most of my box.
      • blueflash234
        • Mar 2009
        • 904
        most of the things on the ts panel you will get on the vix servers apart from softcams but if you google vix softcam pack then ftp it to the temp folder and install you should be good to go
        • P&D
          • 2686
          No i asked you which version you have tried to load
          there are quite a few versions
          I had trouble with the low version using blackhole it would only install the later version 7.2
          • cactikid
            • 12017
            if you download plugins from menu in vix,unsure if its an extension but i use ts media as ts panel was removed.
            • jacquesy90
              • Dec 2013
              • 92
              dont know what ive been doing wrong but everytime i install a plugin box freezes up.
              finally got ts media working before. but thats it, scared to install anything else
              • happy_highlander
                • 3535
                Set up file swap on box to help reduce freezing and green screens specially on solo and duo
