Hi guys, small problem which may have happened last night because of the high winds, turned my vu box on tonight and no signal, I've a motorised dish with single lnb- the dish moves fine I've searched for a few satellites but no signal at all , and the motor has a flashing green light & red light when not moving, I've also tried a second box and it's the same with no signal,would I be right in assuming the problem is the coax from motor to lnb or the lnb itself ?
No signal
Tags: None
Yeah the dish may have dropped down a bit, strange that I can't find any signal from the other 3 or 4 I drove the motor to, I can't get up the ladder until tomorrow so hopefully it is just the alignment.sigpicComment
Found out what the problem was - I must be blind I didn't see it in the first place ! The wind has pushed a large dent outward from the back of the dish ! ,ive pushed the dent back out a bit - but is this dish knackered now and would I be wasting my time putting it back up again ?IMG_0603.JPGIMG_0604.JPGHi guys, small problem which may have happened last night because of the high winds, turned my vu box on tonight and no signal, I've a motorised dish with single lnb- the dish moves fine I've searched for a few satellites but no signal at all , and the motor has a flashing green light & red light when not moving, I've also tried a second box and it's the same with no signal,would I be right in assuming the problem is the coax from motor to lnb or the lnb itself ?Last edited by shankill2012; 4 February, 2014, 23:00.sigpicComment
