starview the box pvr channel editor
  • steady--1
    • 10
    I have the pvr uploader program, the channel editor software, the null modem cable that came with the box and a serial/usb convertor
    I have installed the driver that came with the serial/usb convertor
    I connect the stb and pc, start the uploader, select com 3 and the channel data option then click on upload, I choose file name then hit save
    A progress bar opens saying uploading, but stays at 0% I have waited ages nothing happens
    I have tried version 3.36 and 4.01 of the loader
  • mkwabbey
    i have the same problem can anyone help
    • steady--1
      • 10
      sorted
      I have sussed this out, you need to put the box into boot mode, do this by switching off then on using switch on back of box keep pressing ok/exit (usually 3 times) box will say boot then display b-61
      you should now be able to download and upload channel list
      remember to set com port in device manager and pvr uploader to same port
