Protek 9750 patch & channel list
  • dick b
    • Jun 2009
    • 2462
    As requested by DW190 last patch made for 9750HD and a current channel list. most of the 9750s are no longer connected so be warned you may not open anything.
    the Favorite 1&2 are all blue button channels but Fav 3 has mainly FTA at the start for 28.2E.
    0118 is the list and GNX the patch
  • Timex
    • Feb 2014
    Hello,
    I very new at this. But do you think that I can use your included file to retrieve all the channels that have disappeared from my protek 9750HD. Kindly guide me from the basics. I will highly appreciate.
    • mdt
      • 3034
      Originally posted by Timex
      Hello,
      if your box has been removed from/blocked from connecting to the darkforces server which most of the early serial number 9750,s have then it looks like your out of luck although there is no harm in trying the posted software. if the boxs still connect via the mac addy like the old 9600ip,s used to you might be able to fool the system by changing the mac address if possible. if you cant connect to their system then you will need to look for a third party N connection but its something we cant discuss or help you with here on dk as its against forum rules. ive not owned a protek for a couple of years but im sure @dick.b will be able to advise you better than i can atm,regards mdt
      • Minisun
        • Mar 2014
        Hello,
        Hello
        I'm in the same hardship as you...do you find any solution ? If yes , please let me know it. Thank you in advance
        • dick b
          • Jun 2009
          • 2462
          You wont find a solution I"m afraid as all 9750s have now been taken off the server and patching wont help as its done by box serial number.You will need to buy a 9720 HD or a 9770 HD to get the same service as before or you could go for the cheaper Mvision 260HD wifi but be warned its no where near as reliable as the protek Do not buy a 9760HD as they will soon start to be removed as well I guess.
