Help with buying and setting up new system
  • chris120383
    Hi Guys,
    I have been paying for sly since the days of the eurovoxs hitting the wall and im fed up with it now.
    I know there are a few ways to sort out a new system to get all the sly channels but im not well educated on it.
    Can someone give me some advice. I need a box I can plug into exsisting sly dish and what software or firmware is required and where to get it.
    Or even point me in the direction of where I can have a good read up and learn a bit more so that I can set a system up.
    Any and all help is welcome.
    thanks guys
  • ramjet
    • 2995
    there is plenty of info on here about setting up sat boxes and even motorised dishes , like here http://www.digital-kaos.co.uk/forums...-setup-301108/
    but you wont find any on circumventing sly as its a banned topic
    these boxes are not sold on that basis and its a sensitive subject, its certainly not a method of "saving money" and as such is illegal , hence why its not "talked about"
    • mdt
      • 3034
      get yourself a motorised dish.... with a triax td88,darkmotor,black ultra,tm5402hd and t+k brackets there is a wealth of programming available using softcam,biss,fta and feeds before you even consider using the lan feature.
      if you fit it yourself your looking at ?230 or about ?350 installed by a professional. once you see whats out there on other satellites you will never pay for sly again. regards mdt
      • P&D
        • 2686
        If you just want the regular channels the one your sick of best bet is have a good read in here Openbox/Skybox
