hi guys i have a spiderbox 7000hd i cant seem to get the channels on the new astra satellites ..no itv hd and channel 5 etc can anyone help
Astra 2f channels not appearing on spiderbox
depends on your location as to whether or not you will receive the new channels and transponders
see here http://www.digital-kaos.co.uk/forums...-spain-402066/ and here too http://www.digital-kaos.co.uk/forums...ss-box-400293/ -
I read elsewhere that ITV hd is under a new transponder because Astra are shifting a satellite . Rescan might be in order.
I know nothing about spiderbox so maybe a scan is not possible, so excuse my ignorance.
FlySat Eutelsat 28A - Astra 2A/2E/2F @ 28.5/28.2? EastOfficial Meat-Head Fan Club Member (member number 14300)Comment
There is nothing wrong with the Spiderbox range persay its just that they are no longer supported with firmware updates, the reason you may not be able to scan these channels in is because they are probably not in the transponder list on your receiver.
Have you tried doing a Blindscan in either 4 or 2mhz steps on 28.2? east as this may pick up the non-existent TP's
Thanks digicon i did a blindscan i had no idea i could do that , and all the missing channels suddenly appeared great...i am still going to replace the spiderbox there is just no support for it.There is nothing wrong with the Spiderbox range persay its just that they are no longer supported with firmware updates, the reason you may not be able to scan these channels in is because they are probably not in the transponder list on your receiver.
Have you tried doing a Blindscan in either 4 or 2mhz steps on 28.2? east as this may pick up the non-existent TP'sComment
