Dr Hd D15 help with firmware prog list etc
  • skeggyhornet
    • Mar 2014
    just bought one of these boxes and can not find out anywhere how to set this box up do I need to put updated firmware onto it to use all the features and how can I create a favs program listings anyone can help
  • mdt
    • 3034
    this firmware will give the extra features your after.... as for a channel list you will have to make your own or use someone elses. ive attached the latest softcam and the list of whats open via emulator,regards mdt
    • skeggyhornet
      • Mar 2014
      thanks for the response have bought this from my supplier and is supposed to be a really good box all I need now is a program list I wonder if I could use one from another satellite box technomate, dreambox etc
      • mdt
        • 3034
        you can use any with the CNDF file system like the TM5402HD.... this is a FTA/softcam list by william-1 to get you started,regards mdt
        thanks to @william-1 for his list
          If your only using this on 28.2? east then you can use the Happy Highlander one which is very good: http://www.digital-kaos.co.uk/forums...6/index25.html and he even does a Multisat for the most popular 4 satellites here: http://www.digital-kaos.co.uk/forums...32/index3.html
          Basically you can use any premade channel list on the D15 from the following receivers : TM5402HD,Blade7000s,Clark Tech 4100,TM F3/5 as they all use the same .cndf file system
          • skeggyhornet
            • Mar 2014
            thanks guys for all your help
