Thor and intelsat can be got on the same position [as stated]..But it all depend's on your receiver some receiver's have the firmware to find both [transponder's are different]..Some rx's [like the old technomate etc] have not got intelsat stored as a seperate satillite so it comes up as thor/intel..adding transponder's will find the channel's you want[on each sat] or you could add a new sat[renaming eg intel 10-02]..doing a single transponder search eg 11785 H 28000 then storing it, then after it is stored do a full sat search on that transponder [eg network scrambled fta etc]..this will then seperate the two sat's[after storing the new named sat]..
Hope this is of some help.
regard's.
