Giga blue quad plus worth a look?
  • blueflash234
    • Mar 2009
    • 904
    #31
    completely of topic i see red apple also has the prism cube for sale
    • westkill
      • 2378
      #32
      Originally posted by happy_highlander
      That's correct but C/T will get you hd cable but only sd terrestrial. Whereas C/T2 will get hd on terrestial as well.
      yesterday ordered GiGaBlue Hybrid DVB-C DVB-T2 Plug and Play Tuner Module to go with it
      • rhurbarb
        • Aug 2009
        • 180
        #33
        I have sent mine back to be tested .For some reason when i enhanced the sharpness of the picture it went the opposite way and started to blur the picture instead.I may have to change my reciever to another
        • RuberDuck
          • 1724
          #34
          I have heard vix are working on it but not from the horses mouth so it could just be garbage.
          well now you have, yes we are working on cable for ABM and will be available in the next image, but we do need help from any user in a pure area, interested users pm me for details.
          • westkill
            • 2378
            #35
            all up and running with open mips 4.0 image fast response on the remote and downloads
            crossepg running well using xepgdb works way quicker , that downloads pretty quick alot faster than me dm800
            put about 10 plugins on and no lag to the image no crashes realy to speak about only on some plugins which happends on any E2 box any way
            well nice big screen on front of box
            so all in all i like it
            • happy_highlander
              • Aug 2010
              • 3535
              #36
              Mine arrives on Thursday. Red apple were out of stock though so ended up getting it from ebay.de shop thingy. Worked out at 291 delivered with cable tuner already installed
              • westkill
                • 2378
                #37
                dont think your be disapointed highlander i tryed the hybrid tuner with with terristrial aerial works well
                just need to get some cable to try the hybrid tuner with cable tv side of things and see how that goes
                added the coolman epg plugin working well with crossepg
                and look for a different skin to cause the default one dont look to hot
                • happy_highlander
                  • Aug 2010
                  • 3535
                  #38
                  Try openatv it is an absolutely cracking image. Same Button layout as vix. By that I mean channel up and down actually is channel up and down and the likes, the epg is similar to vix so no need for coolmans to be added but everything is as configurable as black hole rather than where with vix an awful lot is done for you and you can't change it. All the cams can't be set to start automatically after gui restart whets that isn't so easy to set on vix. The one down side is it's nowhere near as stable of vix
                  • westkill
                    • 2378
                    #39
                    sounds good m8 think i back this image up and try it and see how it goes
                    • RuberDuck
                      • 1724
                      #40
                      Just like to say thank you to happy_highlander for helping with this, you'r results have been passed to Andy and Peter and will be included in to ABM's DVB-C scanner.
                      https://github.com/oe-alliance/oe-alliance-plugins/tree/master/AutoBouquetsMaker
                      • rhurbarb
                        • Aug 2009
                        • 180
                        #41
                        Hi Westkill .I was very impressed with my gigablueplus quad for speed but i did have an issue with the defintion on some sd channels.You couldnt confrim when sharpning the picture in av settings it gets worse before it gets better ? Thanks m8.Rhurbarb
                        • westkill
                          • 2378
                          #42
                          i never realy touch the av setting to much usally just use the tv settings more than anything but on the whole some sd channels seem beter than others dont no if thats a broardcast thing or not on some channels i guess
                          • rhurbarb
                            • Aug 2009
                            • 180
                            #43
                            Thanks m8 .Not sure if this is the way the guad is programmed or i have had a reciever which hasnt been fine tuned correctly.Shame i havnt got another giga here to test it against the other .
                            • westkill
                              • 2378
                              #44
                              maybe future driver software updates ? possible , have you tryed your box on different tv or with different hdmi lead m8
                              • rhurbarb
                                • Aug 2009
                                • 180
                                #45
                                Hi Bud.I did try another image .Also on another tv too..And i tried two other hdmi cables.I tried what i could because i really wanted to keep this box
