motor problem vu+
  • gingeee85
    • Jan 2012
    • 197
    motor problem vu+
    ok i have a vu+ solo and everything has been working well, trouble is when i now change satelite to 28 its going to 34 or something like that, the same is happening if i try go to 19, its of to 25 or something. anyone know how this can be rectified, i did have a vhannible list on but since removed and just focusing on 28 until i can determin the problem
  • DigitalVandal
    • Jan 2014
    • 138
    Check your longitude/latitude settings are correct.
    • gingeee85
      • Jan 2012
      • 197
      yes they are correct
      • Nutsandbolts
        • Oct 2011
        • 1168
        Hi. If you are using USALS you can loosen the dish slightly and move it back until you get a picture then tighten dish up again. With USALS once you have found a satellite the rest should come in assuming your dish angles/LNB skew etc are correct. If you are 6 degrees out it means your alignment is out.
        Regards
        • gingeee85
          • Jan 2012
          • 197
          yeah cheers mate, have tried re alighnment twice and it does the same thing
          • Nutsandbolts
            • Oct 2011
            • 1168
            Hi. Well as you have tried re-align it twice and its doing the same thing then if possible try using 1.2 instead of USALS and see if motor moves between 28 east and 19 east. Not familiar with your receiver but i assume it does have the 1.2 function to move the motor. Also what make of motor is it and how old is it??
            Regards
              Just for clarification on the motor scale on all Diseqc motors dont pay a blind bit of notice of what it reads underneath when your on a satellite, as most in the UK are around 2-3 degrees west of due south so 28.2? east would add up to around 31? east anyway like i said the most important part is to get the alignment correct, Another thing to consider is the recent winds a few weeks ago could have already added a little play to the motor stub so when the dish moves around the far reaches of the ARC it will tilt that little bit further than it should if it had no play in it at all.
              Regards
              • ramjet
                • 2995
                agree with digicon , if you are focussed on 28.2e using the correct usals then the markings on the motor will NOT be on 28.2e for most users and will be a few degrees out. this is normal and you should not confuse the motor markings with the actual satellite position
                my zero marker on my motor will actually point to say 3 west or 4 west as I am in the west of the country, so my 28 east position will not be anywhere near 28 east as shown on the motor markings
                the ONLY important marker is that your zero point on your motor should point exactly at true south so if you were on the uk west coast this would be something like 4w or 5w in reality from a satellite point of view, meaning you would pick up fta channels from 4w or 5w when your motor is on zero using its etched housing markings
                the trouble is when people start using the motor markings to think that sly should be on 28e on the motor, this is rarely the case for most people , hope that helps
