mine worked ok m8
do you not see it in menu > setup> service searching > tuner configeration as c tuner
or menu > setup > service searching > manual scan and scroll to the right as c tuner
i take it you must tryed pull the power and back on again
Same as westkill my hybrid tuner was recognised straight away. Just to add even though westkill has advised you correctly make sure the tuner is seated properly or even try it in the other slot
same here, although i have no access to cable or a tv ariel my third tuner a dvb-c/t combo tuner was detected perfectly, as above make sure it is seated correctly before any further fault finding.
