Removing stored sat positions
  • Docker Doyle
    • Jul 2013
    • 23
    Could anyone help me please, I have my system set up, a motoriesd dish and a Protrk 9750, unfortunatly the strong winds here keep blowing the dish out of line on the side of the house, so i'm building a ground base with walls at the rear and sides to protect the dish from the wind, I need to clear the stored sat positions on the protek box so I can re-do it, can anyone tell me how to unstore the set positions Thanks
    Docker
  • markwi
    • Jan 2014
    • 133
    I don't know your make of receiver but you could edit the channel list with a program called NDFEdit which can work on .NDF or .CNDF files.You get your channel list off the receiver,onto a pc and use this program.Then put the modified channel list back Cheers. Mark
    • Docker Doyle
      • Jul 2013
      • 23
      Thanks for the reply Mark, but its not the channels I want to unstore it's the actual sattilittes stored in postions on the box
      • markwi
        • Jan 2014
        • 133
        Why do you want to clear the sat positions?I take it you don't want to delete the satellites,as I mistakenly thought.If you're talking about re-locating the dish all you need to do is set the dish to a satellite south of you,from the box,and then move the motor on the pole until you get a signal.This is assuming you haven't changed the dish/motor relationship.You may have to adjust the elevation a bit as well.I take it you know the pole has to be perfectly vertical.Good luck cheers Mark
