ASTRA 2A 28.2E - no signal???
  • joveljic
    • Jun 2014
    • 8
    Was happily watching TV when all of a sudden started getting scrambled or 'no signal'. Turns out there is no signal coming via Astra 2a 28.2E??? I can only detect 2/3 of a signal from Astra 1H/K 19.2E but as you can imagine this one is one brodacasting fraction of the channels.
    Anyone else have this problem?
  • ramjet
    • 2995
    working ok here on several boxes from 3 different dishes , so the fault is with you
    • WOODWARD395
      • Apr 2010
      • 628
      If you were watching TV at the time and all was well sounds like dish has moved by wind or LNB faulty to me.
      Look at the simple things first don't complicate it its normally a simple tweak here or there.
      Education is not the learning of facts, But the training of the mind to think
      So hit the thanks button if I have enlightened you.
      • royboyz
        • 205
        Check cable not come out of connector
        Sent from my iPad Air using Tapatalk Pro
        • joveljic
          • Jun 2014
          • 8
          Thanks for all your suggestions guys. It's really weird but this is how I resolved it. I went into the Menu options and wanted to do another scan. This is where you can tell the system to scan for channels on another satellite and this is where I noticed that some other satellites were broadcasting a signal of some sort. Only by accident, I changed the "TP Index" for Astra 2A and noticed that some other indexes where showing full signal. I did another search using the new TP Index value and all channels were ok.
          I am not an expert on this, but I assumed that when searching for channels on any satellite that it would go through all the different frequencies and display all?
          • ramjet
            • 2995
            not all boxes do a blindscan, in which case they scan the transponders in the box`s internal database , so no they dont do a "catch all" scan of all frequencies
            a blindscan on a suitably equipped box is what you are thinking of
