TECHNOMATE 5402 HD ci , Need latest patch and channel list
  • fadastarky73
    • Nov 2012
    • 11
    Can anyone help me get the latest patch and channel list for the above.
    I currently have patch 1.36p.
    I'm new to this so I will need install instructions as well.
    Thanx in advace
  • ramjet
    • 2995
    try the technomate forum
    also look in here as well for the channel lists posted by tm5402 owners and blade bm7000s owners, like the highlander ones
    • digicon
      • 8261
      TM5402HD
      Latest Patch can be found here:
      http://download.for-better.biz/bbs/list.php?board=tm5402hd
      Be careful as there are 3 models of the 5402 Mark 1,2,3 make sure you get the correct one for your receiver
      Channel lists can be found here for 28 east only: http://www.digital-kaos.co.uk/forums...bm7000-267416/
      • markwi
        • Jan 2014
        • 133
        To load these files you need to get them,uncompressed,onto a usb memory stick.Then put the stick into the receiver.Press the Menu button.Then select USB/External Device.Then select File Manager/Download/Upload.Check "File" is selected and if you don't see the files,use the up/down and Ok buttons to navigate to where they are.When you see the files highlight the .stb file(patch firmware) and press ok.The new firmware will now be loaded,the receiver will tell you,and will reboot.After,repeat the procedure for the NDF file(channel list).Cheers.Mark
