Blade 7000s problem
  • ron292001
    • 82
    Blade 7000s problem
    Hello all
    I have a blade 7000s and its been work perfect for over a year now. But out of the blue its started freezing every 5 to 10 seconds. When i turn the box off and leave it for 30mins or so then turn the box back on its fine for about 10 minutes then starts freezing again. I no its not my server because when i put and openbox on it works fine. Do you think it might be overheating or something like that?
    Thanks for any help given Ron...
    Remove the Lid and check for swollen Caps, Sounds very much like the PSU could be on its way out
    • ron292001
      • 82
      Thanks digicon
      I hope it isn't the PSU as that sounds unrepairable I will check what you said. Thanks again for your reply..
        Everything is repairable especially if its just the cap's as these are pence if of course you feel confident with a soldering iron
