but i can not get it to open any channels im using a technomate 6900 super wat should the config b on this cam i.e au off etc many thanks peter
i have updated my diaBLO cam to underworld 1.82
M8,are you using the latest key's bin file?..i think on some receiver's 182 can be a bit buggy.. have you tried reinserting your cam [rebooting]?..if that fails go back to 181 with the latest key's [that should work].. also reformat your cam hope this is of some help..
regard's,
terry.Comment
Same old
I'm going through a similar process with CANAL+NL on 19E, which was working with UW 181 until I tried to improve it to UW 182. Lost the channels, have reflashed (after reformat) to 181, won't work on that now either. GRR.
Waiting for the keys bin file when I work up enough posts.
I've a FORTEC STAR INNOVATION HD, Technomate TM2600, Diablo 2.3. Anyone else have issues with Diablo & Fortec?
RegardsComment
Kitchen Sink
I finally tried to restore the diablo set up from before uw 182 (using a backup file made before all of this) - this has not worked, and is giving new problems. The Fortec is not recognising the reloaded CAM - still thinks uw 182 installed and will not access the CAM from the receiver remote (can normally view info & keys as a sub menu - but not tonight).
At this stage I'm taking a break before I create any more havoc.Comment
