Hi Guys,
Setup:
1X USB Sat Tune
1X Desktop PC
1X Sky Fibre Broadband Router
1X Fibre Modem (Standard one)
1X Laptop (Connected to a friends network to see if it works over the "internet" as opposed to locally on the same network)
*1X Static IP (this will be requested later<<)
I hope you can help. Basically what I'm trying to achieve is to stream FreeSat channels over the internet. I have a desktop pc with a USB sat tuner plugged in. All free sat channels work fine on the server. I am using software called "progdvb" to view these channels. The program has a built in server setting that allows you to stream channels over the internet. I have done everything I think to make it work but it still does not funciton. To be able to stream you need to open ports 10999-11000 I have done this and verfied with a port checker that these ports are open. I have also disabled windows firewall and antivirus and the firewall on the Sky Router.
On the laptop (Client machine) I've also disabled all firewalls and done port forwarding on here even though it may not be required. I've even put this into a DMZ as well as the server I cannot play any streams.
The problem I am having is that by going to my ip address (152.X.X.X) using a friends connection I can bring up the channel list. However when ever I click on a channel it points to (192.168.0.10 <My server machine) of course this will not play as this machine is not on the same network. If I connect my laptop to my 192.168 network which the server is on I can stream fine as its all being doine locally.
Do you think there is a problem with port forwarding?
Do I need to login in to the Huawei Modem as when I looked at the WEB GUI a long time ago it did have options for firewalls? or does the Sky Router over-ride the firewall rules?
Hope you guys can help
Setup:
1X USB Sat Tune
1X Desktop PC
