hello guys ive got a blade box and the motor will move but it will not pick any signal up the bars are red picking nothing up is there something ive not tweaked
no signal
need more info really is this a new instal etc;
if you are using usals send the dish to say 28.2E then try adjusting your longitude position in the box by 1.0 degrees at a time east/westward til you get some sort of signal then change to 0.2 degrees at a time to fine tune but make sure you have an active TP set in the box -
Hi dick thanx for replying its not a new install i did take the lnb cable out of the back to try the line on another box but it still didnt pick anything up and when i put it back into the blade 7000 s it wouldnt pick anything up just 84% red bars no green i live near wigan and i put the lats and longs in the box and pressed goto still nothing ive even set it to thor still nothing ????Comment
send your motor to zero and then switch off/on at back and try again. if you need a installer to sort it PM @digicon,regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
