multiblock LNB
  • ukbackups
    • Oct 2014
    multiblock LNB
    hi looking for a bit of advise looking to get multiblock installed
    what would be the best setup
    ie what satellite to point at for football and hd channels from Europe
    i live just outside manchester
  • den1
    • 63
    what sat's are you thinking to pick up, football can be received from various sat's 10e/39e/15w most of which clear with the soft cam on the Technomate receivers.
    DEN
      An 80cm minimum size dish would get you 13?,19.2?,23.5? & 28.2? east quite easily with a wealth of channels between 4-5000 approx.
      • Nutsandbolts
        • Oct 2011
        • 1168
        Hi i would personally go for a motor like a TM2600 which will give more satellites than a Monoblock LNB. Only go for a motor if your dish size is at least 80cm to give you more choice.
        Regards
