[HELP] Satellite LNB
  • cikoleko
    • Feb 2012
    • 26
    Hello users, I'm not an expert and don't understand the signal processing so can anyone tell me does a good LNB make big difference? At the moment I can't tell you what LNB I have so let's says it's bad so can you recommend me a good one, thanks. By the way I'm connected to 3 different satellites so they all go through DiSEqC connector and then just 1 cable enters my receiver so is DiSEqC important component as well?
    Depending on what Multi LNB setup you have on one dish then the Inverto Black Ultra is highly regarded as the best on the market
    • cikoleko
      • Feb 2012
      • 26
      I have two LNBs on 90cm dish, one is pointed at 4.8e and other is pointed at 13.0e
      • Nutsandbolts
        • Oct 2011
        • 1168
        Hi... what is the third satellite?? In my opinion if you only watch one satellite at a time you would be better off getting a motor like a TM2600 which will give you more satellites and dont need any extra LNB or Disecq switches etc. Motors are very easy to set up.
        Regard.
        • cikoleko
          • Feb 2012
          • 26
          Regard.
          Third satellite is 28.2e but it's on the other dish
          • smokin
            • 255
            look at the lnb, the lower the number the better, so if the value is like below 1.0, then fine, if above, dump it.
            The best is like 0.3 or .2 or .1 subject to opinion
            Does it make a difference, yes, it can make a big difference, on bad signals.
            Technomate-Dreambox-Spiderbox
