Blade Media 8000 Combo Receiver *Firmware*
    Hi All,
    For anyone thinking of buying this receiver with its built in DVB-S2 tuner and DVB-C/T/T2 tuner i have uploaded the patched 9991 firmware to the download section
    Regards
  • tony_i
    • Oct 2008
    • 425
    Originally posted by digicon
    Hi All,
    Regards
    What are your thoughts on this box mate?
    I'm confused about the second tuner. Is it suitable for UK cable?
    Will your Blade 7000S sat channel list work on this?
    I have to say I've been pleased with my 7000S and at this price I could well be tempted if the cable aspect was as good as the sat.
    • joe516
      • 1000
      I'm confused about the second tuner. Is it suitable for UK cable? yes m8 it is
      Will your Blade 7000S sat channel list work on this? it have blade on online for sat not cable m8
      • tony_i
        • Oct 2008
        • 425
        Badly worded question by me.
        I know the list won't work for cable, but I was wondering if digicon's excellent sat list for the 7000 would work for sat on the 8000.
        • mdt
          • 3034
          if it uses the .cndf file system it will work,regards mdt
            I have a sneaky suspicious feeling that it will use a .CNDF/.NDF format for the channel list as when i had my Dr HD Grand Triple which had a slot for a pluggable tuner inside the .NDF channel list right at the very end was the setting for Cable and terrestrial built in. Now the downside CTeditor which most use as its the best editor for cndf files does not like a .cndf or .ndf file with the terrestrial and cable extension inside.
            Dont take my word as gospel that the 8000 will use a .cndf format but looking at the receiver Top Cover in the photo's its identical to the new Technomate F3/5 and TM 5402M3 sat receivers which may suggest it comes from the same factory which would suggest it uses the same file sytem.
            • WOODWARD395
              • Apr 2010
              • 628
              Has anyone got the vm channel list for this box 8000 or point me in the right direction. thank you.
              Education is not the learning of facts, But the training of the mind to think
              So hit the thanks button if I have enlightened you.
              • tony_i
                • Oct 2008
                • 425
                Lists for the cable side of things will be area-dependent, won't they? A list made from a London feed will be useless elsewhere, or so I understand. It's not like a satellite list. I assume Blade will produce an editor for this.
                Do you have one of these boxes? How have you found it so far?
                • WOODWARD395
                  • Apr 2010
                  • 628
                  No its for a friend looks okay. From what I have seen.
                  much prefer the reliable enigma2 box not relying on one source.
                  Sent from my GT-I9505 using Tapatalk
                  • WOODWARD395
                    • Apr 2010
                    • 628
                    Here's how to scan courtesy of DELTAWING
                    ok what you do is goto tuner2 scan
                    then select powerscan select 6952 as your symble rate and press scan its gonna take a while to scan but should get about 350 odd channels, i have the newer firm on mine but were testing that should be able to release that in the next day or so
                      **Update**
                      New Firmware released Blade 8000 Combo 108p ( Fixes to Cable Scanning Problem )
                      Regards
                      • satcrazy
                        • Oct 2011
                        • 4
                        There's no "BISS" option. On this firmware.
                        • tempo123
                          • 344
                          Hi all, can someone point me where to get more info on this box please? Many thanks
                          • stavros67
                            • May 2013
                            • 81
                            Removed Link
                            • tempo123
                              • 344
                              Well thank you.... But I have already visited the blade home page...... I would like to know where to find the latest patch and other people experiences on the box......
