Help Upgrading Current Satellite Dish
  • dashlee
    • 73
    Hello, im after upgrading my satellite dish to something a bit better. I am currently using a Sky MK4L, although i no longer have Sky. I am looking to get a better dish with more connections so i can put satellite in another room.
    Can anybody suggest any good satellite dishes or packages that would be suitable
    Thanks in advance
  • ramjet
    • 2995
    if you only need more conenctions change the quad lnb to an octo, giving 8 conenctions instead of 4
    then run in more shotgun cables or singles
    if you want a bigger dish or motorised dish , consider the better quality ones of between 80cm and 110cm
    like
    gilbertini
    triax
    technomate
    raven
    favel
    orbital
    philex
    and add an inverto ultrablack lnb with enough outputs to suit what you want (typically 1 or 2 or 4 outlets)
    • cactikid
      • 12017
      one thing to remember will you be adding to it as people do and go for an octo as a quad only runs 2 twin tuners and people do dabble more and want more,cheers ram.
