No channels coming through after list update.
  • LewHand
    • Apr 2013
    • 23
    Hi Guys
    I put a Dm800 in on OpenPLI for a friend of mine who lives in Spain on 28.2E and he said that he was slowly losing channels like usual.
    He did not have a laptop handy to use Dreambox edit on so I teamviewer'd onto his tablet and using a FTP client I loaded the new Bouquet files into /etc/enigma2.
    After restarting the channel list loaded fine but every channel was saying check Tuner Configuration.
    When he checked it looks like the Satellites.xml had been wiped out as there was no options to select a Satellite. This was weird as the Satellites.Xml is loaded in /etc/tuxbox.
    So I loaded a new one in, tuner config come up fine and then done a manual scan which finds 700 channels which looked ok.
    However when trying channels now only Chanel 4 and BBC 3 come through.
    I've tried multiple satellite xml backups and generated a new but the same as well as trying different bouquets.
    Any ideas on what else to try as that's all I can think of. Do you think it may be worth try long a factory reset and starting fresh?
    Thanks in advance
    Sent from my C6903 using Tapatalk
  • mdt
    • 3034
    seen this before on my 800se, try @rats list for 28.2east. before you upload the list send the list in the box over to a new folder on the pc and delete the satellites.xml file also,regards mdt
    • andy91
      • 3583
      No need to double post you will get an answer.
      Andy
      • LewHand
        • Apr 2013
        • 23
        Sorry will close this one
        • LewHand
          • Apr 2013
          • 23
          Is this rats autobouquets?
          Had a look through the forum but haven't found any downloads for it
          • mdt
            • 3034
            took this of my 800se, its a bit different but its based on @rats list so all credit goes to him,regards mdt
            • LewHand
              • Apr 2013
              • 23
              No joy, even flattened it and started from scratch but nothing. It picks up 600 channels when scanning
