which box yo upgrade to from f5s?
  • tony34567
    • 102
    #16
    Originally posted by redondo5
    does the wetec play allow you to install emulators like neogeo or fba retroarch for android?
    Still think the zgemma S2 and H1/2 look better value for what yo get
    can you provide more information about installing neogeo.
    i will try in mars android satellite receiver.
    • redondo5
      • 277
      #17
      Well i just did a brief google search and read on another wetec forum about others trying to install emulators and having problems...
      However you could try installing retroarch... The apk can be installed from google play shop or even any downloaded apk file i would assume as long as permissions allow. Sorry can't give you any instructions, havn't used an android receiver myself.
      • colpac
        • Aug 2012
        • 49
        #18
        I have just changed from a skybox f5 to a zgemma h1. Bit tricky to get set up but once you get the hang of it it is easy enough. Its sat & cable and have got both working no problem and it is a big improvement over the f5
        • RTR1879
          • May 2015
          • 14
          #19
          Anyone know the difference between the ZGemma H1 and H2? Is it just that the H2 has a black case and a slightly better Samsung cable tuner?
          Probably going to get one for some Enigma2 fun and games in a week or two.
          • vorlon2257
            • Sep 2011
            • 356
            #20
            H1 has Satellite and Cable tuners, H2 has satellite tuners only
            • RTR1879
              • May 2015
              • 14
              #21
              Are you sure about that, Vorlon? Everything I've seen about the H2 says it is 1 x S and 1 x C, the same configuration as the H1. The S2 is (as you would imagine) 2 x S.
              • vorlon2257
                • Sep 2011
                • 356
                #22
                You are right and I stand corrected, the H2 is the same as the H1 only in black, the S2 is the twin tuner version.
                • tony34567
                  • 102
                  #23
                  Successfully configured Neodroid apk for Neogeo games in Mars Android Satellite Receiver.
                  • happy_highlander
                    • 3535
                    #24
                    The H2 is not the same as the H1 the H2 has 512mb flash memory and dvb-T2/C as well as dvb-s2 tuner whereas the H1 has 256mb flash memory and dvb-T/C with the dvb-s2 the colours you have correct.
