Swap file on Giga blue quad plus
  • WOODWARD395
    • Apr 2010
    • 628
    Ok I know its easy to put a swap file on the VU+ BLACK HOLE IMAGE but is there an advantage putting one on the Giga blue Quad plus and if so how can you set it up on the quad.
    I use kodi direct and thought a bit more memory may help.
    any advice welcome.
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
  • cactikid
    • 12017
    swapfile are only used for old slow crappy boxes like solo and duo which love the spinning vix image ,did not think your box was crappy?
    it could slow box down as not needed.
    • WOODWARD395
      • Apr 2010
      • 628
      thanks m8 thought that but have other problem cannot get box to boot at all since new update stuck in a loop cannot get past splash screen keep you updated.
      bear with me.
      • jovie
        • Oct 2008
        • 100
        the reason your in a loop is because your flash memory is not erased properly regards jovie
        • WOODWARD395
          • Apr 2010
          • 628
          Thanks I know but tried flashing with several USB'S every one would not flash eventually got a flash of an old USB I had it was the usb's that through me as I used 5 different ones to try and flash then used one of my older sticks to flash and hey presto it pays to get the decent usb sticks.
          • cactikid
            • 12017
            correct many times i have said get good makes of usb ,i use integral 8gb which flashes when doing something,and have stuck in rear an 8gb kingston micro usb for epg and swapfiles on solo and duo,hope you have not forgotten usb for epg setup??
