Openbox V5s Problem
  • TJ2013
    • Oct 2013
    Openbox V5s Problem
    When i programme the box FTA channels work perfect
    When scan channels only some prem channels appear and some dont
    When i put on AJ sat list only afew prem channels come on but others say no signal
    Have got the no signal fix still the same, have changed antenna still the same
    Any Suggestions
  • P&D
    • May 2010
    • 2686
    Might help if you post the question in the right forum http://www.digital-kaos.co.uk/forums...Openbox-Skybox
    You would get more reply's
    Check your firmware version could be the problem & may need updating
    if you have an official S^y box connected (on a loop)....disconnect it....see if this fixes the problem
    is the AJ's channel list the latest one ??http://www.digital-kaos.co.uk/forums...=1#post2520858
    • TJ2013
      • Oct 2013
      Sorry for posting in Wrong Section
      Yeah have reflashed, AJs is the correct one
      Sly Sports 1 doesnt come up along with movies SD when i do a blind scan
      Heads Wrecked
      • P&D
        • May 2010
        • 2686
        Not a problem mate ......just pointing you to the best place to sort your problem.
        Re-post in the open box forum
        Explaining what the firmware version is on the box
        how you have the box setup
        what channels you have missing
        there are many people in that section that can help better than i can
        • Nutsandbolts
          • Oct 2011
          • 1168
          Hi. usually if blind scan dont find channels it means your dish may be out of alignment. I would personally delete all the TP's and do the blind scan again. If channels still not found then tweak the dish a little and redo the scan.
          Regards
          • TJ2013
            • Oct 2013
            Cheers Folks will do
