At times,Rai 1,2 &3 encrypt programmes that breach international rights.This results in Italy football matches,Formula 1 & certain films being blanked out on satellite.Can anybody tell me how I can enter keys on my T Rex Cam to view these encrypted programmes.There is a file you can flash on certain decoders to do this,yet I have to use a Cam & enter keys manually.Any ideas?I know what the hex keys are for September,& I do not want to post them on here as this would be unethical.Any help would be appreciated
Rai file for encrypted programmes
***************************************At times,Rai 1,2 &3 encrypt programmes that breach international rights.This results in Italy football matches,Formula 1 & certain films being blanked out on satellite.Can anybody tell me how I can enter keys on my T Rex Cam to view these encrypted programmes.There is a file you can flash on certain decoders to do this,yet I have to use a Cam & enter keys manually.Any ideas?I know what the hex keys are for September,& I do not want to post them on here as this would be unethical.Any help would be appreciated
it's easy mate put the cam in the receiver [ this is for a t-rex super cam]
turn on and press menu>and go to ci in the cam menu
and you will see the file thats on the cam.click>ok on this
on the next panel go to [3] debug>ok
next panel [2] sucka>ok
next panel [2] sucka 1>ok
next panel [2] 0030: rai>ok
next panel you see three choices go to the key line
you wish to enter the key for and click>ok
on the next panel you se a black square and two dashes
now you enter the set of three number keys in the correct order
after entered exit the menu and the channels should openPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish, -
Thanks.I will give it a bash***************************************
after entered exit the menu and the channels should openWinning fair & square is the hardest thing of all in Serie AComment
I did exactly as you said above,Benny,yet the certain programmes remain encrypted.I used to manually update Polsat keys,so I knew how to do this,yet there is no joy with Rai.Any ideas what the problem could be?Is it possible the software has been set to stop manual updates on Rai?Its been annoying me for a while,any help appreciated
P.S.The Cam works fine with an Al Jazeera card just nowWinning fair & square is the hardest thing of all in Serie AComment
