Satellite Feeds
  • satsid
    • Aug 2009
    • 815
    #121
    Originally posted by satsid
    Rangers v Unirea Urziceni on 10e in 4.2.2 s2
    id fi05lndn
    11011h 9874 3/4
    Martin this one back on in 4.2.2 m8.add it while transmitting m8
    • martin-f
      • 535
      #122
      i have tried both feeds sid and i am not getting anything atm just going to try the first feed again thanks m8
      martin
      • satsid
        • Aug 2009
        • 815
        #123
        Martin this is a good one 2 add called up4.
        10971v 4167 5/6
        on 10 east
        add just normal this one
        • satsid
          • Aug 2009
          • 815
          #124
          martin
          Still there m8 atm,just to help.
          • satsid
            • Aug 2009
            • 815
            #125
            Whats your dish size martin?
            • martin-f
              • 535
              #126
              hi sid
              its 1mtr
              • satsid
                • Aug 2009
                • 815
                #127
                should be ok unless wether bad m8.
                • martin-f
                  • 535
                  #128
                  hi sid its my side for some reason my dish as locked of sat just trying to lock back on
                  • satsid
                    • Aug 2009
                    • 815
                    #129
                    ok Martin m8,add this one first once back on 10e.Should have no bother getting this one in.Once you have tell me what signel strenth you have from up4.
                    cheers
                    10971v 4167 5/6
                    on 10 east
                    ps back switch on & off m8,mines done this before now on azbox receiver.
                    • martin-f
                      • 535
                      #130
                      ok sid
                      will give it a go as i am using 1.2 i keep having to go outside to see where my dish is at be right back
                      martin
                      • martin-f
                        • 535
                        #131
                        cheers sid
                        turned it of and on from back locked on to sat just going to try up4 will let you know results thank
                        martin
                        • satsid
                          • Aug 2009
                          • 815
                          #132
                          cheers sid
                          martin
                          ok m8,let me know how it goes.just made a drink.
                          • martin-f
                            • 535
                            #133
                            hi sid
                            i just cant lock on to them for some reason
                            all the tp i have put in theres nothing there one tp that i left and thats
                            al-forat
                            11175 H 2532 that is ok
                            • satsid
                              • Aug 2009
                              • 815
                              #134
                              hi sid
                              al-forat
                              Hi martin iv just added your one & i have about the same signel on up4 m8.so you should have no problems as you have your tandberg one
                              ps if anything i have more signel on up4 just
                              • satsid
                                • Aug 2009
                                • 815
                                #135
                                martin your dish is big enough for up4 as you got the tandberg one.Keep going & your pick this up,we staying with this feed as there is always signel.it does not go off.
