Im about to install a 1.2 channel master pointed at 1 west. but in the future i would like to be able to recieve more satellites without installing a 36v motor. Is there a multi bracket for the 1.2 . Whats the most amount of lnb's i could put on it. I would like to get; 1 west , hotbird, astra 19.2, sirius. Just say i wanted these sats which one would i have to point the dish at first before i install the rest of the lnb's.
can i put more than 1 lnb on a 1.2 channel master
************************************************** ***Im about to install a 1.2 channel master pointed at 1 west. but in the future i would like to be able to recieve more satellites without installing a 36v motor. Is there a multi bracket for the 1.2 . Whats the most amount of lnb's i could put on it. I would like to get; 1 west , hotbird, astra 19.2, sirius. Just say i wanted these sats which one would i have to point the dish at first before i install the rest of the lnb's.
a 36v superjack motor and a v-box so it can be moved by a diseqc receiver
wont cost much more than 5 or 6 lnb's and the fitting to mount them plus
it will give you most sats from 45e to 45w and only one universal lnb
it's a waste of a good sized dish being fixed even though without subscription
there is'nt very much open on most satellites at this time
if you are set on a fixed dish i would make hotbird 13e the prime targetPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish, -
Hi m8..the multiarm bracket is universal and just screws onto
the end of the lnb arm...its basically a strip of metal and will hold at least 3 lnbs as well as your existing one....you will have to bend it a little though to get the focal points correct...
I once had one on a 90cm fixed system and had no probs getting thor,19e,and 13e off the same dish...
allign the dish on thor cos this is the weakest,then put the multiarm bracket to the right of the dish(looking from behind the dish)and the eastern sat beams will bounce off the dish to the right...Comment
