zgemma h1 and motorised system
  • BRUTUS
    • 37
    Hi all,
    my zgemma h1 is connected to my motorized system and the virmin cable, everything works fine except that the box doesn't drive the dish correctly (not at all actually). Any luck from you guys?
  • digicon
    • 8261
    Sounds very much like a PSU problem and the motor not getting enough juice to move, i setup a couple of these for friends on motorised systems and there's worked fine
    • BRUTUS
      • 37
      Thanks mate, but i am still struggling to set it on motorised. Did you use a ready to use setup plugin like Mali... or you did set each sat individually? do you have a backup available? i am using openatv firmware.
      • digicon
        • 8261
        None of the above just setup USALS entered Longitude and Latitude settings and then downloaded latest Vhannibal motorised setting via the plugin job done
        • BRUTUS
          • 37
          cool, ok let me try that
          • BRUTUS
            • 37
            Struggling big time... which one of the Vhannibal do you use? Did you get it directly from the plugins or you downloaded it from another source and then send it to the box ftp??
            When downloaded directly from the plugins download, which one do you use?? (so many of them there...)
            • digicon
              • 8261
              I use the Autosettings Plugin which can be downloaded from the plugin download section under 'Extensions'. Install then download your chosen channel list.
              It is also available from here: Vhannibal
