French channels on sky zone 2 dish?
  • giraffe
    • May 2013
    • 10
    Looking for some advice to get some French channels on my setup, which currently consists of a Zone 2 mini dish with a quad LNB focused on 28.2 and an additional LNB at 19.2 (receiver is skybox f5)
    From looking online there are free to air channels available on 9 degrees E - I'm thinking that adding an LNB to span 28.2 to 9 will be too much,
    So a TNTsat card for 19.2 would be easiest, will this work with skybox f5 ok?
    Any other advice?
    cheers,
  • M T Glass
    • Jul 2013
    • 733
    Are you picking up anything from 19.2E?
    I'm not sure about slybox f5 but it used to be that sly boxes were useless for anything other than the purpose for which they were built, which is 28E.
    19E is a strong satellite but it has some similar transponders to 28E where you might think you are picking up a 19e transponder when in fact it is the strong reading from 28e.
    9e would be out of the question and I only state all of the above based on sly dishes here in Ireland which are all 80cm. size.
    Official Meat-Head Fan Club Member (member number 14300)
      Just useless imo on all fronts
