TM500 v DM500
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    TM500 v DM500
    Ok, after having a fair bit of time with both these receivers i can tell you that the TM500 does everything the DM500 does but has a few extra options like audio priority (i think that the dm has that in neutrino), there is also a menu where you can retrieve your ISP ip. the TM runs cool and never crashes unless you have the twitchiest fingers going. turns the motor relevenly fast. The DM however IMHO has slightly better pic.
    The TM500 doesnt have composite ( the three holes ) but the dm does.
    Also i have had a few glitches with the download server on the TM using UR image but thats fixed now and im put to using the tm500 now instead of the dm500.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
  • red devil
    • Oct 2008
    • 690
    both my DM500 & DM600 have a better pic than my sly box
    • satman
      • 736
      This is available in enigma images in all boxes,, including dm500.
      again, dreambox code and code was contributed by Cli team, so works on dreambox, itgate and tm.
      The Diseqc enigma code is exact same,, perhaps a slight better tuner in tm box, ( especially if your comparing against a clone dreambox ), so no differnece in motor code between dm500 and tm500.
      The DM500 should never have a better picture quality to be honust,, the iTgate sister box is far superiour to a dm500, although we also have component ( 3 holes too, but red,green and blue, )for video.
      the UR server is fine, and has had no down time in 3 weeks.
      see comments in RED
      boom!
      • dowlinr
        • 226
        I use audio priorty on the Pli jade image and pretty sure it was in Nabilosat when I was using that.
        • .: JaCkPoT :.
          • 5607
          I dont see it on nabilo. Ok after reading the red it seems as if the dm500 is better But why are these extra functions not default in nabilosat?
          ___________________
          DM800s HD
          Openbox S10
          TM500
          DM500s
          Maxx 110cm Dish
          • dowlinr
            • 226
            Go to the web interface and click configuration-->settings, then scroll down and you'll see Audio Channels Priority
            That's where it is on Pli anyway.
            • satman
              • 736
              Exactly,, and is part of any image that uses expert web interface( in otherwards its from tuxbox-cvs code ),,, which by the way is included on nablosat image.
              boom!
