setup advice
  • stephen211270
    • Aug 2015
    setup advice
    Hi Guys
    First Time Doing Motorized Install could you just confirm a couple of things . this is my Latitude:53.4382? and Longitude:-2.9691?
    so would I put the first 4 no is my box not sure on the Longitude also my lnb should be set to 0 and with the connection part facing downwards at 6'oclock and I should be trying to get a good fix on 72.1e Intelsat 22 (is-22) / 0.8w Intelsat 10-02/Thor 5 Thor 6 and 78w Venesat-1 to get the best Arc also I have set my Elevation Angel on my motor to 53 and on my dish Bracket is at 27 . apologies for all the questions
    Technomate TM5402 M3 ...
    Maxx Digital Satellite Dish 1.1m ....
    TECHNOMATE TM-1 SUPER HIGH 0.1dB SINGLE UNIVERSAL LNB
    ..SUPREME DARK MOTOR LED METAL GEAR DiSEqC 1.2 / 1.3 USALS
    thanks for any help or advice
  • ramjet
    • 2995
    the motor bracket should be on 53.5 , not 53, then lock it tight
    depends on the box as to what you put in the longitude, but minus means you are west of the london meridian , so you may need to put the figures in and choose west
    if they are too long to fit in the box, reduce it by altering the last one or two numbers , so 53.4382 can become 53.438 , or 53.44 for example
    your zero marker on the motor points to true south, you may not even have a sat there , but that is where it points, to true south (not magnetic south)
    then you send the motor to 0.8w using usals and find thor by moving the motor left or right on the pole, and the dish up or down slightly
    then check 42e and 30w , checking all reasonably good sats in between too , you wont get much outside of these figures , so not 72.1e or 72w
    when you can see the arc and get good signals from them, lock it all up
    • stephen211270
      • Aug 2015
      Cheers mate
