Cloud Ibox 2 plus boot problem
  • elad
    • Sep 2012
    • 41
    hi I've got a problem that is the box says Boot in the front led screen I've tried a few images to reflash but with no luck can anyone help out there please
  • DOUGALMCD
    • May 2011
    • 3229
    Did it just happen on it's own or did you flash it with image and then it happened and if so where did you get image from? Maybe you don't have correct image. What image did you have on before ?
    • elad
      • Sep 2012
      • 41
      it just happened on its own i switched the box off at the back as i was moving it into a different room then i switched it back on and all i got was BOOT on led screen and nothing else
      • DOUGALMCD
        • May 2011
        • 3229
        Get the correct image for your type box and put on formatted usb turn off box insert usb in rear and wait for it to say done if not about 30 mins turn off and remove usb from rear. Get image from www.cloud-ibox.net make sure you download the correct one for your box. hth
