I have a problem with my ZGemma, works perfectly one minute then if I reboot I lose certain channels such as sly one with no signal but other channels work ok, I know the LNB is ok as I have tried 2 and they work perfect with my dream box and open box, do you have a clue what the problem could be thank you
Open open ATV 5.1 I have tried it both on and off, also simple and advanced LNB configuration, like I said it doesn't happen all the time, but quite a few times and it gets frustrating as the only way I get them back is re-flashing the box, as anyone else at this problem then?
The only time I've seen this problem was due to a Openatv OTA firmware update, but this problem was rectified by the way described by lincsat above. As your using an Openatv Backup image ie mine, you could try updating to the latest one I've uploaded. If that still has the same problems then best way to eliminate an image problem it is to use another backup image, as I've seen your post on another forum you should have access to either thomas88 openhdf image or sucmnsee vix image, if the problem persisted with these images then as your other boxes are ok there's a hardware problem with your box.Comment
Thanks...Fingers crossed it seems to be working ok for the last few days, all I did was like previously mentioned switch disq to on which I thought I'd already tried,,, can someone point me in the right direction to set this up with my 1m motorised dish I used to have my dreambox working perfectly with the motor but that was a while ago and can't remember how I did it. I know I've got to go into advanced LNB settings and switch discq to 1.2 I can remember that much..
... If there's any tutorial videos about or its been discussed before, if someone could point me to the links that would be much appreciated
Thanks againComment
