Doh! Got it. Thanks
Initial EPG problems turned worse....!
Download this file [ATTACH]354976[/ATTACH] and extract it then ftp .ipk file to tmp on box using dcc and install then reboot, then go to menu>setup>crossepg>configure and set it to download to your usb/hdd/storage device and force epg to reload on boot=yes, update daily at around 0530 or about 15 mins after your autobouquet updates then go to opentv providers and enable astra 28.2 only save it and download.
Job done cross epg will fully populate epg evry morning at your specified time.
Done this but cannot save it because the green save button is not selectable, as is the yellow and blue, in fact the only button I can select is the Red (back button), I'm using Openatv 5.1 on a Zgemma H.2H, should also add it's the same on my Brothers Zgemma H1.Comment
You will then need to go back and choose 28.2 from opentv provider then enable then download. Sorry my bad for not telling you it needs to know what sat you want to download for in that post.
Edit..........
No is not my bad i did tell you to what you need to doComment
Already done that in the first install, but done it again and it is still the same, have enabled the skyuk 28.2 in opentv providers hit the download button to download the epg data, it does save it automatically when it's finshed doing it but if I go to the configure part of crossepg the green yellow and blue buttons are still not selectable.Comment
MartinAs you've flashed images before it might just be easier to flash this image and follow the instructions in the thread, your
goes in the same place and as Mt's
http://www.digital-kaos.co.uk/forums...proved-ky-Skin
Real nice image, looks professional and the kids like those little yella fellas.
Everything went smoothly following your guide but I'm having probs with the bit thats not in your guide! I've looked through threads here, on other forums, google, you tube and even tried watching some german video (but thats a different matter!). Im really stuck and know its taboo so would there be any chance of a PM???Comment
Yes that is correct you only have the back option in configure which takes you back to the main screen where the rest of your options will become available when you select the sat to download data for. Not once have i ever said there was a save function in the configure screen. What i said was to configure the settings then go to opentv and enable/save the sat and download. Job done. It will now run at the given time you set up in the configuration screen.Already done that in the first install, but done it again and it is still the same, have enabled the skyuk 28.2 in opentv providers hit the download button to download the epg data, it does save it automatically when it's finshed doing it but if I go to the configure part of crossepg the green yellow and blue buttons are still not selectable.Comment
