change the lnb to a twin or quad and run extra coax cables , so if you wanted 4 feeds buy a quad lnb
do not try splitting a sat feed , it wont do what you want, each tuner or box requires a separate coax feed from an lnb output, which is why sly plus had a quad lnb fitted to the dish
