Hi all, got a zgemma H2S running openATV ver5.3 a couple of weeks age set up by supplier,initially epg was running fine, now it's only free to air that seems to populate fully, the others some are now and next others not at all. Reading the forum it appears the epg should be saved to tf card or hdd. I have set up an external hdd and can record two channels at once proving the lnb's. Should I have a tf card in the small slot on side of box? And epg set to save to that? Pressing the green button on remote I can see xmltv which shows import configuration, any help with that please. still bit of a newbie with box and don't want to mess things up!
EPG not loading properly
Tags: None
Because of the constant access, the EPG and timeshift if set to auto should be saved to a USB stick drive or microSD card, mechanical hdd are best used for recordings.
As your rear USB is populated by a mechanical hdd then the easiest option would be to use a microSD card and use that for the epg and timeshift but get a nice and fast card ie class 10.
Sounds like you need to update your rytec sources but as I use crossepg I'm unsure on how you do that.Last edited by martin035; 16 April, 2016, 01:01. -
